Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52вопросов Показать все
Вопрос закрыт
in LCD the brightness
Hay. i change the screen LCD in IPAD 2 3G but i don't know what happen. She was working and every thing it's ok. One time i turn off the ipad and turn on more time, i don't see good in LCD the brightness is to low and i can see any thing!! and i want to know why is happen
iPad 2, iOS 7.0.5
Update
this is my problem in my LCD screen i can see very will
Update
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Give it a hard restart
Hold power and home button for 7 seconds then let go of home and keep pressing power see if that sorts it..
Был ли этот ответ полезен?
Оценка 1
8 Комментариев:
no is not working
из
the lcd screen don't have light i can see ever will i should to look in hard way
из
Is it working only the brightness is very low?
из
yes more than what you think i have photo i want to send you it to see ho is it
из
try to see what i min the this photo you can see something but you shiuld to look good to see what i want to tell you
из
Показать 3 больше комментариев
If you tried Reset and it did not help ... so components backlight burned.
This happened because as you disconnected the lcd screen the ipad was on.
Solution requires soldering
No backlight and LCD replacement didn't fix it..
Оценка 0
Friends, try to Power Off the Ipad 2 and turn it back on, a normal reboot and for me it worked, was changing the digitizer and suddenly backlight stop working and hardly saw the screen,, was going crazy until I managed to reboot (power button doesnt work) and started with backlight.
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 169
