Why does my iPod show a folder with a warning sign?
My iPod shows a folder with a warning sign and below it the words www.apple.com/support/iPod. What could the problem be and how can it be fixed?
Это хороший вопрос?
Это хороший вопрос?
normally that would mean that the hard drive of the iPod needs to be replaced - any clicking sounds in the past ?
Был ли этот ответ полезен?
please click here - expecially the posting that is shown first (you should read the rest too - but this one could be important
since the link i wanted to add is a little bit censored, i can only recommend you a googe search with: "iPod diagnostic mode" <- use it incl. the " - the first result should give you some informations about the diagnostic mode and how to verify your harddrive without the use of a computer
good answer +
Go to www.apple.com/support/iPod like it says.
There are several different warning signs that Apple uses. Please take a look at this link: http://support.apple.com/kb/HT1378
to identify which one you have and the probable fix.
fresh research +
Why do I have a triangle warning that says NO COMMAND?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 2,620
