Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Why is my screen black after I dropped it?
i dropped my phone on the floor and then i picked it up as soon as i could! when it hit the floor back down, the screen slowly turned all red, then completely black. it still vibrates, charges, and makes noises. i dont know why the screen is black! i tried getting into the back of my phone and i was making sure everything was in place and in order. i tried resetting it too. help!
Это хороший вопрос?
Оценка 11
Добавить комментарий
4 Ответов
Наиболее полезный ответ
The lcd connecter could have popped out make sure it is still connected but by saying the screen turned red the black I think you have busted the lcd and need a replacement
Был ли этот ответ полезен?
Оценка 3
My phone did the same thing and I didn't no what to do I thought I broke a pixel but I don't no if I did will a screen replacement fix it?
Оценка 1
1 Комментарий:
I need to know this too my phone did the same thing should i just replace my screen or take in into apple?
из
Both of you need a screen replacement, luckily this is very very easy on a iPhone 5C and the full assembly with backplate, home button and lcd in one should only cost a little over $10. follow the guide from ifxit slowly and you should have a good screen all fixed in around 30 minutes.
Оценка 0
Same thing happened, my phone fell to the ground and it was black when i grabbed it
Оценка 0
Добавьте свой ответ
amanda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 7,665
