A popular graphic calculator released by Texas Instruments in 1996.
12вопросов Показать все
Why is my screen faint?
My calculator was working fine until this morning during a test the screen turned super faint. It didn't die because I can still (almost) see the numbers.
The batteries are new but I tried other ones just in case.
Any ideas?
Это хороший вопрос?
Оценка 2
1 Комментарий
My TI83 has a similar problem. When I switch ON, the screen has vertical lines where the pixels don't come on. The calculator works fine except for the vertical blank lines. When I use the calculator for some minutes, some of the vertical blanks become functional again. But there are always one or two lines that remain. Some thermal-related problem?
из
Добавить комментарий
2 Ответов
Выбранное решение
Janessa, try to adjust the brightness. The contrast on your screen might have reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly. Hope this helps.
Был ли этот ответ полезен?
Оценка 10
8 Комментариев:
Holy $@$* you just saved my life
из
thank you so much
из
Thanks! That worked great
из
Tried changing brightness/contrast, but the screen is still faint, I am hardly able to see the numerics on it.
Any other remedy?
even unable to find a service centre in Mumbai
из
Just reset the calculator!!
из
Показать 3 больше комментариев
Check the battery contacts to see if you have some corrosion on them.
Did you spill anything or stress it with some weight resting on it?
Оценка 2
1 Комментарий:
Tried removing and cleaning the battery contacts, but the screen is still faint, I am hardly able to see the numerics on it. Any other remedy?
Any other remedy?
из
Добавьте свой ответ
Janessa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 36
За последние 30 дней: 159
За всё время: 24,296
