Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Вопрос закрыт
No charging or data connection
Got an iPhone 5 in where the customer had attempted to change the power/volume flex. In so doing he's done something to the lightning connector as it won't charge or connect for sync.
I've changed out the lightning connector assembly and replaced with a new one, no change at all. Had a close look at everything and can't see any damage. Tried two new lightning connector assemblies now so pretty confident it isn't that part.
It's odd as he's actually managed to replace the power/volume flex properly, but I'm at a loss as to what he's done to cause this issue. Any ideas what it might be that is broken?
Это хороший вопрос?
Оценка 0
1 Комментарий
It certainly seems that the damage is to the logic board but I've looked at this and compared with a working one and can see no dislodged components. I think I'm going to have to give up on this one.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
He has damage some part of the logic board seems a comon issue with the 5 .
As you no yourself all the little components on the board around the battery area and were the charging port connects could be easily knocked off if you don't no what your doing
Был ли этот ответ полезен?
Оценка 1
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 82
