The current line of iPod touch comprises seven (7) different generations.
2615вопросов Показать все
iTouch stopped working after being dropped in cereal
My son dropped his iPod Touch into his cereal bowl this morning, milk and all. It stopped working as a result.
My current plan is to give it time to dry out and then see if it will start back up.
Is there anything I should/could do prior to trying to start it back up?
Also, if it doesn't start back up, is there anything else I can do?
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
your idea to let it dry out first is a good one, it may take time to dry out thoroughly
there's another almost identical question from about an hour ago, rather than repeat what was said perhaps take a look over here:
How do I fix a wet iPod?
good luck
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Thanks! I'll give it a shot.
из
Liquid damage is a killer for electronics. First thing is to turn off the iPod and remove it from it's power source. Hopefully this will prevent the logic board from getting shorted out. Next, I recommend taking the iPod apart following our guide and letting it dry out for a few days. While the iPod is apart and drying out, you can use some rubbing alcohol and q-tips to try and clean any milk residue you see. The rubbing alcohol evaporates quickly and will not damage the iPod further. Finally, put the iPod back together, cross your fingers, and hope it works.
If that does not fix the problem, then you probably, at minimum, need to replace the logic board. Hope that helps you.
Оценка 2
1 Комментарий:
Thanks! I'll try drying it out, following the guide.
из
i had same problem with a pool though and yea i just let it dry out and it works for the most part fine now
Оценка 0
Добавьте свой ответ
carlweir будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 4,990
