Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218вопросов Показать все
Screen stays black and Ipad is beeping after replacing digitizer
Hi. I´ve replaced the digitizer on my iPad and everything went nice I thought....
But when I tried to turn the iPad on nothing happens :(
If I put it on the cable or plug it into my Mac it is only beeping exactly every 6 seconds. I reopened the iPad to have a look what is happened. All cables are connected and nothing seems wrong!!!
What may cause the problem? Please help :(
Это хороший вопрос?
Оценка -1
1 Комментарий:
Same error with the old digitizer. Im Not sure if the homebutton line is ok. May a broken homebutton cause this error? What to do now :( its broken !@#$...
из
Добавить комментарий
1 ответ
I would look at a faulty digitizer; you can use the old digitizer to confirm if you have saved it. You may have shorted something out during the install was the iPad powered down?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
paraa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 228
