A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
42вопросов Показать все
Find a good replacement screen for Nokia Lumia 1020?
I had my Nokia 1020 run over by a car and it works fine I just need to get the screen replaced... since it is scratched and a little cracked. I only have 60 and need an LCD Screen Replacement. Can anyone help? I can't transfer data to the computer anymore though and if I was to send it to nokia they will destroy the data and send me a new phone...... I have so many things I can't loose off the device like pictures and accounts....
Это хороший вопрос?
Оценка 1
3 Комментариев:
I think replace a screen doesn't need to destroy the data. Have you consult Nokia?
из
Yes I have actually... They said they have to replace the device completely due to the damage.... So I have to get the data off the phone.... And there is no way possible... I have taken over 5,000 photos on my trips..... They wont upload to Skydrive.... Nor to my email....
из
The pictures and some important data inside the phone is the most troubling. You can visit this site to find out whether it's worth or not to buy a new one to replace the old. http://www.dbx.com.cn/Products/LCD-for-N... or this site www.3cline.com .The first is for wholesale,but you can contact them for a single sale.
из
Добавить комментарий
2 Ответов
Reagan Games, even the cheapest LCD will still run you around $130. You can fix it yourself, check this video for the how to. The data will not be erased by replacing the display. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
I dont have the money.... I need tools... And the part.... Nokia says I need to replace so many parts.... Like the back housing.... The camera piece.... And the USB port.... Since the phone was run over .... But I just want to replace the screen.... I could try to match a price for it...... If any help is available.... I am so afraid to loose the memory and everything
из
I do feel for you and your dilemma, but there is no cheaper way. Sorry.
из
I connect the USB charging cable to my Windows 8.1 and back it up. The images are found at \Windows Phone\DCIM\ and just move them all to My Pictures folder.
Оценка 0
2 Комментариев:
I found new glass for 1020 on eBay for $10.
из
you can't replace just the glass. I tried, it is completely bonded to the LCD screen. The LCD and glass together cost me about $90. Also make sure you get the screen with the plastic mounting frame attached to it.
из
Добавьте свой ответ
Reagan Games будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 12,945
