1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192вопросов Показать все
3 Long Warning Beeps
Hello all, today I heard, for the 1st time, a sequence of 3 long beeps from my MacBook Air 11' mid 2011. It was in sleep mode but felt extremely hot. Also I noticed that the battery had gone from 96% when I put it to sleep to 65% in the 15 minutes that it was asleep! When I opened it up it didn't start, pressed the power button for 5-6 seconds and thankfully it powered up and I was taken to the login screen. Have been using it now for last hour and battery use is normal.
After some frantic googling it seems that the 3 beeps are a warning for bad ram? Is it possible to swap out the ram? Would be confident enough of opening up my beloved, have previously used ifixit for iPhone 3G & 4 parts/guides so hopefully this can be done!
thnaks for taking the time to read my question :)
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
The RAM on your machine is "onboard", that is built into the logic board. It cannot be changed or upgraded after purchase. I would keep a everyday Time Machine hard drive (SSD) backup. Your machine could last a long time or it could fail in the next 5 minutes. "Therefore keep watch, because you do not know the day or the hour."
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
thanks for the quick reply :)
из
Добавьте свой ответ
collinsmikep будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 695
