A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
10вопросов Показать все
Red light no matter what?
Hi, I have a google chromecast and when I set it up everything worked perfectly. I unplugged it for the night and then I plugged it back in and it had a red light. I tried factory resetting it but the light still stayed red and the reset button is not stuck. Anything that I can do?
Thanks
Это хороший вопрос?
Оценка 3
Добавить комментарий
4 Ответов
Выбранное решение
Try swapping out the USB cable that comes with it, apparently several people were given a cheap faulty USB cable that would stop working after a day or two. Many have found salvation by using a known good USB cable. Let me know if this doesn't work. Oh as far as the reset button you should feel a definite click, if you don't press the button repeatedly to loosen it up.
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
Changing the usb cable worked for me. thanks so much!! such a simple solution but had me stumped. thanks again.
из
I have an original 2013 Chromecast and it just stopped working now - July 2022! I know this is an old post, but just commenting as I came across this, and tried changing the cable as a last attempt before throwing it away and it worked!
из
Hi
Mine did the same. My Ccast remained plugged in and working great for a few months. Then one day, I noticed the LED was off.
I have tried many power supplies and cables. No luck. Even with a USB inline volt and ammeter plumbed into the supply. It shows no current draw from the C-cast.
Anyone else have this. ??
Оценка 0
i am using the chromecast 2 audio only mode with 4k hdmi converter, red light always blinking bt it extracted audio perfectly.
Оценка 0
When I turn on the chrome cast the white light is blinking. But it is not showing in my device
Оценка 0
Добавьте свой ответ
Ted Mayer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 48
За всё время: 26,026
