AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
Why does my cord not charge my laptop?
I have a 17inch Mac Book Pro 85W Mag Safe power adapter that does not seem to charge my laptop anymore. Any suggestions on what the problem is and how I can fix it? Thanks in advance.
Это хороший вопрос?
Оценка 1
1 Комментарий
I need replace my cord, any suggestion for which one is best for mac book pro 15".
из
Добавить комментарий
Ответов (4)
Выбранное решение
Chris, sounds to me like you may need to replace the Apple AC Adapter, or possible the power jack may be damaged. Your best bet is to start with a new adapter to see if your laptop will charge afterwards before moving on.
~Gadget~
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Do you get any lights on the adapter plug? Download and run Coconut battery to see if it is still capable of holding at least a 20% charge of original capacity. http://www.coconut-flavour.com
Оценка 2
2 Комментариев:
No lights or charging sign on the screen. If the wire is in exactly the right place the light will appear. Very clear that the wire is frayed and gets connected if positioned perfectly
из
You can replace the wire. Go here to get the part: http://www.ebay.com/itm/Original-OEM-App.... Opening the case is the hard part as it's glued together and taking it apart without destroying it is hard and requires brute force.
из
One of the two cables might have broken off of the pcb inside the main housing of the power adapter. The cables have crimped ends which can break due to cable-movement, causing erratic loading/not loading although the light is constantly on.
Оценка 1
1 Комментарий:
The cables in this case are the wires inside the cable from the power adapter to the macbook.
из
Having checked the T connector for shortcuts and found there wasn't any, I dismantled the connector and checked if the charger unit was O.K.
The multimeter showed 16,68 V.
Finally I found out that the fault was in the wall outlet, which didn't give proper contact to the charger.
So always start with the simple solution :-))
Ole
Оценка 0
Добавьте свой ответ
Chris Ferris будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 3,951
