Headphone Jack is Damaged.
My headphone jack is not working properly. When i plug in any headphones no sound can be heard on the right headphone, only the left one works. What is the fix for this?
Это хороший вопрос?
Это хороший вопрос?
Assuming you've tried a different set of headphones and your sound is still acting up, i would say go to the Accessibility tab in Settings and be sure the Mono option isn't checked. It's only supposed to convert stereo audio to mono for single-speaker plug-ins, but it may be glitching. Otherwise, you probably have a faulty headphone jack.
If it isn't a setting, you may have a damaged headphone jack, it is easily replaced if you go to this link:
Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly Replacement
Let me know if you need any further assistance :)
~Gadget~
Был ли этот ответ полезен?
Checked with different set of headphones, mono setting also turned off. Wireless bluetooth headphones work fine. That means it is probably the headphone jack.
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 169
1 Комментарий
Have you tried using a different pair of headphones? Do you remember when the issue started happening?
из Gary
