Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
62вопросов Показать все
CD stuck inside the unit. Help?
I have a mac mini as listed A1103 it belongs to my girl theres a cd inside the unit and it doesnt come out and seems to be causing some kind of error because the unit doesnt post. Is the cd inside causing the problem, in any case this is the issue how do i take the cd out?
Or do i have to replace the optical drive?
Thanks in advance.
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Restart holding down the mouse button and it should eject.
Also try:
Open the Terminal in the /Applications/Utilities/ folder and run:
drutil eject
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
thanx let me try that now! im not very talented with macs. I work for HP maybe thats the answer but thanks!! another quick question..that is causing the problem of being unable to start up?
из
Let's get the CD out and see what it looks like. The unit may boot fine. If not let us know and we'll diagnose further.
из
If your CD is stuck and none of the other methods work, you might eventually try pulling out your optical drive and doing this: Optical Drive Disc Removal Technique
Оценка 1
You could also try the
double sticky tape trick,
There's many reasons to fail POST however AFAIK a stuck CD is not one of them.
Оценка 0
Добавьте свой ответ
Ramon Aviles будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 9
За всё время: 3,418
