How do I change the MAF (mas air flo) sensor?
Does the 2001 Honda Accord have a MAF and where is it and how do I clean or change it?
Это хороший вопрос?
Это хороший вопрос?
that depends on the used engine. the 4 cyl. has a MAF and the 6 cly. has a MAP sensor
maybe this helps you (the engines are not always changed after a modelchange): http://www.driveaccord.net/forums/showth...
Был ли этот ответ полезен?
2.3 accord does not have a MAFS, it works of the MAP sensor.
works off of MAP sensor, has no MAFS.
thx
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 51
За всё время: 17,052
1 Комментарий
Seriously? Are you sure it is bad? There will only be tiny bits of carbon in it. Why do you think you want to clean it?
из Dave
