The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
Battery drops from 100% to 7%
I bought this phone from eBay. Turns out it would only turn on unless I charge it for hours! So I bought a new battery and it began charging and turning on. I disconnect it and it would be fine for like 2 or 3 minutes. Then it would all of a sudden drop from 100% to 7%. I don't think its the battery because I bought an OEM battery. But it could be defective. I'm not sure. Any help?
Это хороший вопрос?
Счет -1
2 Комментариев
Does any part of the phone overheat?
из
No. Not at all. It works normal then the battery power just drops.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like there may be a task left open in the background. Press and hold the back arrow to see if there are any tasks left open? If not try a soft reset first by pressing and holding the vol down+power button. You shouldn't lose any data doing this but some have reported their clock resetting.
Another thing to check. Goto settigs>Applications>photos+camera. Is Auto upload to Skydrive on or off? If it is on, your phone may have apent hours trying to upload to Skydrive if you have a slow internet connection. If connection is slow, you might want to consider turning this off.
If all else you may need to replace the battery.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Jon Andrade буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 448
