Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
On 16 colors display
I recently change my LCD but after a week my display is turning into 16 colors and sometime black out but it woul return to normal everytime I turn off and on the display.
<a href="http://s484.photobucket.com/user/muddy_f... target="_blank"><img src="http://i484.photobucket.com/albums/rr203... border="0" alt=" photo 2C55CB38-E8AD-4E7F-AA4F-9427B1A4FE0E_zpsphmizzvy.jpg"/></a>
One technician told me that it could be the audio codec. Does anyone encounter this? How to fix it?
Thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Hi Deck,
When I encounter this, I usually assume the part is defective and see if the problem persists on another screen. In testing I have figured it is the driver IC on the screen assembly, replacing it with a known working one fixed the issue. Unfortunately this is a advanced repair, and you would need a donor screen (maybe your old one?)
Good luck!
Был ли этот ответ полезен?
Оценка 0
Hi!
Thanks for your reply.
Yeah I think it is the driver IC, the one that on the flex cable. Maybe the technician told me it was my audio codec since he doesn't want to replace the LCD that I bought from him :(
Оценка 0
Добавьте свой ответ
Deck будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 100
