Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
little inductor broke off logic board, not the blue coil
hello,
2 little pieces have broke off the logic board.
They're located here
and the little one next to it
could that be the reason i can't get a signal?
keeps searching or no service..
Could it be soldered back on and if yes, what are the names of the inductors?
thanks a lot
Updated image
Это хороший вопрос?
Оценка -1
4 Комментариев
saartje de prijck, your images are a bit to blurry to properly identify your components. Any chance you can post clearer images?
из
thank you so much :)
из
0[image|344932]
is this one better?
i know but i had to resize them :/
из
Thank you for accepting my answer. Sorry, I could not see your image:-)) I added it to the original question since Comments does not allow you to add images.
из
Добавить комментарий
1 ответ
Выбранное решение
saartje de prijck, your images are a bit fuzzy:-) See if this will answer your question.
U3_RF is a RF1642 in a QFN12 package
U21_RF is a 824-2170MHZ filter in a 0402 package. It appears to be one of Murata's "Chip Multilayer LC Filters (BPF)". Something like this most likely.
c46_RF is a 6.3V 10UF 20% capacitor in a 0402 package
Yes, it is possible that these missing components are part of your problem. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
saartje de prijck будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 324
