CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
295вопросов Показать все
What is the best tool to use for the standoff screws?
the bloody standoff screws in the iphone 4 are so hard to find a good fitting tool for! What is the best tool that someone has found to handle the standoff screws???
Это хороший вопрос?
Оценка 2
1 Комментарий
Here you can find different market reports about tools-
https://www.factomarketinsights.com/
из
Добавить комментарий
4 Ответов
Выбранное решение
I take a small Phillips and grind it down flat and that allows me to have connections at all 4 slots. I find the flathead slips out a lot and harder to put back in with flathead.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Excellent solution. This really works.
из
You can find all the repair tools on ifixit. You can see the iPhone 4 tear down and can see the tools.
Оценка 1
Very small slotted (flat) head screwdriver.
Оценка 0
1 Комментарий:
1.5mm flat head has been my preferred choice
из
Since you asked this question, iFixit added a special standoff bit to their tools catalogue.
iPhone Standoff Screwdriver Bit (Item code: IF145-343-1)
I use a 'STANLEY 63-310 U.S.A.' pocket slotted screwdriver for this task. It is good, though not perfect: its blade is just slightly wider than screw head, so it will collide into nearby components. I need to slide it slightly after every half turn, so it overhangs clear/free area, instead of overhanging populated area and bumping into parts.
Оценка 0
Добавьте свой ответ
Stephen Jennings будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 1,689
