Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456вопросов Показать все
Should I attempt to fix top LCD myself?
Hi all,
The top LCD on my 3DS is cracked and needs replacing. It looks like a lot of work, I have done some electronics repair before, replaced screen on iPhone 3GS, replaced the battery in an iPhone 4S. What do you guys think, should I give it a go or should I just leave it to the professionals?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Mary Ellen, all a matter of economics and your own comfort level. Since you do seem to have some decent skills, I do not see why you would not try this yourself. Just follow the guides and read through them a couple of times before you start. It looks more tedious than complicated. I think you should go for it:-) Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks I think I will try it myself, I does loom tedious but I can always put it down and come back to it after I while, thanks.
из
Добавьте свой ответ
Mary Ellen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 105
