After screen repair, digitizer not working. What next?
Replaced logic board and another new digitizer. Still not responding .
Это хороший вопрос?
Это хороший вопрос?
You probably have the wrong version digitizer. Check the cable of the original glass and look at the revision.
Был ли этот ответ полезен?
You're right! Got the same thing, mixed up revision versions and the digitizer did not respond to anything. Worked again when I matched rev 0.0 with another rev 0.0
where did you find the one that said rev 0.0?
Got it off eBay by a Dutch member called ts-shops for 27,50 euro
I have a tab t555 and same issue. where can I get a rev 0.0. or what if I change the connector on the board?
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 2,509
2 Комментариев
my grandson damaged the digitizer on the tab2 can this be fixed or replaced???
из Barbara
How would one go about getting a digitizer with the correct version.
из Stephen Hood
