Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418вопросов Показать все
My airport became erratic, then stopped working, is it maybe the card?
My airport has always functioned well, but recently it became erratic, then today stopped completely.
Any ideas? Is it probably the Airport Extreme card?
How is the card accessed and changed?
Duane
Это хороший вопрос?
Оценка -1
1 Комментарий
No, no bumps, water or other damage. Other people at the same location reported no problems with the WiFi. I thought it was almost certainly the Airport card, but decided to send out the query in case there was some software glitch, connector problem, or anything similar I was not aware of before going to the expense and effort of replacing the card- which I will do now.
Thanks very much for your response.
Duane Bluhm
из
Добавить комментарий
1 ответ
Выбранное решение
Can other computers connect using the same wireless network that you use? If so, it's probably your card.
What does the Network panel of System Preferences look like?
And finally, has this computer been dropped or does it have water / liquid damage?
I can help you more once these questions are answered.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Duane Bluhm будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,285
