Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
Engine cutting off when brake/clutch pedal released
I have a Murray riding mower model 46503X8.
I depress the clutch brake pedal to start the engine. The engine starts easily and runs when the brake/clutch switch is depressed.
If I release the brake/clutch switch the engine shuts down. I replaced the brake /clutch switch and the pto switch, but the problem did not go away.
I did the following test. With the engine running and the brake /clutch switch depress, I engaged the cutting blades (pto switch) and the engine shuts down.
I have an electrical diagram but need help to solve this problem.
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Further checks revealed that the seat switch was defective. Once I replaced this, I was running and cutting the grass.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I had the same problem with the brake pedal but my seat safety switch was disabled before the problem arised.... and everything worked fine ???
из
Добавьте свой ответ
Harry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 17,864
