Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418вопросов Показать все
Backlight working but screen is black
When I turn on my MacBook, I can hear the chime and I see that the backlight is working but the screen is totally black. I can see that the backlight is working because the screen is lighter than when it is off. I replaced the LCD panel, but there is no change. What could the problem be?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
Try an external Monitor. If that works the video chip is fine. Than it can only be the LVDS (video signal) cable or a faulty display panel.
Jeez, we really need a FAQ section here ;-)
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
+ Ralph
из
Using an external monitor gives the same problem. Where can I get a video chip to solder onto the motherboard?
из
Video Chip replacement not DIY
Logic board repair is an art, and requires special (expensive) equipment. You could send it off to have it replaced and re-balled.
Good Luck,
N.
Оценка 0
Добавьте свой ответ
Mike будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,716
