Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Spark at battery connector
Hello all.
To detach the battery on a iphone 5s I used a metal separator. Very stupid off course.
I saw a spark. I connected everything back and try to Power on.
But it did not turn on.
Any change I can repair It?
Fuses or so?
Это хороший вопрос?
Оценка 4
1 Комментарий
When you link the battery happens Spark IPHONE 5S
из
Добавить комментарий
3 Ответов
Выбранное решение
Reconnect all connectors.
If it is still not work, the flex cable for battery or screen may be broken while you repairing.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
Thank you. It seemed the battery was dead by the spark, let the battery think it was 0%.
Nothing could start it. But a connection to the power outlet give it a battery indicater of 1% and after few seconds 94%.
Lucky that everything was working.
из
i replaced my battery and now my phone wont turn on period... i reconnected all the connectors and everything.. but i cant get it to do anything...... help me please
из
Killed an iPhone 4s doing this once. It's a burnt fuse, capacitor or some component.
из
Had a spark while reinstalling the battery connector cover plate. I was using metal tweezers to put it in place. DON'T USE METAL TWEEZERS TO PUT IT IN PLACE! I disconnected the battery and reconnected it and it still wasn't working at all.
I plugged the phone into my laptop and it started up normally. I felt very lucky but if you have this problem hopefully it works for you too.
Оценка 2
I also used a metal tool to disconnect my battery on an iPhone 6s. I got a small spark. The phone after that would not power up. I fulled reassembled the phone and then plugged it into a wall charger. After a few seconds, I got the battery picture on the phone and then it powered back up. No issues now, working fine. So if you have this same issue, try this first before taking it in for repair.
Оценка 1
Добавьте свой ответ
The Chaser будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 31
За всё время: 6,329
