How can I my change battery
hello
I have a htc one(m8)and i live in Iran and here htc dosent have any Representation how can i change my battery please help me .
thank you.
Это хороший вопрос?
hello
thank you.
Это хороший вопрос?
alireza, even so not a guide, the teardown on here will show you what you are up against. It is a bear to open and to work on, not easy. Hope this helps, good luck.
Был ли этот ответ полезен?
The HTC One M8 battery is irremovable and bury underneath the motherboard, so if you want to replace a new one, you have to tear down the phone. You need to separate the M8 screen from front housing, then disassemble the battery. Here is step-by-step tutorial on how to change a HTC One M8 battery for your reference. http://www.etradesupply.com/blog/fix-a-c...
hai have some problem with my htcm m8 when i plug the charger en wont to turn it on ti cane if i plug the charger the batery icon show en stay dear anr a yellow light blinkin all the time
Unfortunately for you the HTC One is probably the worst phone to repair ever made. HTC know the phone is so bad they will even repair your screen one time only
Battery replacement led to the right side alignment being off enough to not allow right margin keys to operate. Example, the "0" key would not work. Also, can demonstrate playing Spyder Solitaire. If upright, the right side columns are immovable. Had to uninstall Swype. Even though I have a paid version, it totally bogs down and stalls the htc 1 m8 after battery replacement. Intermittantly, keys stall in going forward or backward through programs. Will I be able to handle this for another two years? Hmmm.
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 37,503
