Released June 2012, identified by model number 3560.
SSDm Sata install tutorial
How can I install a new SSD mSata on my Vostro 3560?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
There's a daughter board that comes off the main board. Check the Vostro 3560 OM, here. You can see it on Pg. 37. If it does not have the mSATA slot underneath it (opposite of the WLAN card), then you'll need Dell P/N 82PYC. (here's a cheat I know of. If you look in the OM on PG. 23, the last illustration on the page, if you take the bottom cover off the laptop, directly underneath the battery latch, there's a small window in the plastic. If you look in it, you can see the edge of the mSATA socket. If you don't see the socket, you won't have hte correct daughter board, and will need the Dell P/N listed above to add mSATA.
Был ли этот ответ полезен?
Оценка 5
2 Комментариев:
I have two divers that came with the laptop;
@ Liteon it LMS - 32L6M mSATA 32GB (where the operating system and softwares installed on)
@ WDC WD7500BPKT-00PK4T0
Currently, the 32GB is too small and its making my cumbersome. So I want to replace it with a 250GB Crucial -sata ssd. But I have failed to locate where the 32GB sata drive. Can someone help….
из
Dell Vostro 3560 Model
из
Добавьте свой ответ
pedromaia87 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 5,380
