The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
The top lid won't lock
The washing machine’s top lid won’t lock.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
If you are having problems with your washing machine’s lid switch, see the Kenmore 110 Series Washing Machine Doesn’t Stop Spinning When Lid Is Opened problem page for possible causes and solutions.
Door or Lid Latch Assembly
If the washer lid or door won't lock the lock and switch assembly might be defective. This is a very common problem. The lock and switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Main Control Board
If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
minney будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 2,039
