How much Ram is possible?
First. Thank you for your great Guides. With your help i have repaired my iPhone and change the HD from my iMac.
Now i have one more question.
How much Ram can i put in my iMac EMC 2544?
2x 8 GB or 2x 16GB? Thank you for your answer.
Update
One more Question.
I think it should be possible to put the 2x 4GB Ram, which are actually in my iMac, in my MacBook 2009 Late.
In my MacBook are 2x 2GB in .
Is it possible or not? Thank you for your answer.
Это хороший вопрос?
1 Комментарий
Regarding the use of iMac RAM on your laptop, of course the easiest path is to just try them out, being sure to unplug the battery before anything else on the board. They might work..
BUT your iMac has 1600MHz DDR3 memory. Your laptop probably has 1066MHz (1067MHz) installed. I believe using 1600MHz sticks on your laptop will cause your system not to start, or to crash sometimes, kernel panic, etc.
из Rany
