no pressure with filter installed but great without filter
I have a samsung refrigerador rs267td, water pressure has been getting low now no pressure,not frozen installed new filter same thing removed filter works great
Это хороший вопрос?
Это хороший вопрос?
update on problem new filter for a day . had to get service tech ,he came in and new the filter housing was defective ,installed part works great the cost was $323.00 with NO help from sansung they will not cover part one and half years old because of wear and tear the filter was changed twice in that time so much for there great product .
I hope this helps someone ,the repair can be done by any person who is handy I will do it in the next year and a half
Был ли этот ответ полезен?
Is this the part you got? Water Filter DA29-00003G
no we have da29-00020b we have changed it three times in a year and a half with no problem till now
Make sure the cradle has been held down 2-3 minutes to allow the reservoir to fill completely.
This may also be a failing water solenoid.
the water pumps out fine without the filter should i prime the filter
installed new samsung filter bleed air out of system it seems to be working fine now.i hope that was it .thank you for your comments .
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 288
