Is the DVDRW SATA drive port/layout the same as the 2009 Pro?
Id like to put a second hard drive in the DVDRW's place, but i can only find caddies that are built for previous 2009 Unibody MacBook Pros.
My main concern is the SATA plug on the 2010 DVD drive and if its the same as the older models (all-in-one connector but smaller power than usual, 6pin from what i can gather).
Here is a couple of pictures of the caddy I'm looking at if it helps, and thanks in advance to everyone.
Pic 1
Pic 2
Это хороший вопрос?
Оценка -1
4 Комментариев
Looking closely at the pictures unless one of the pictures is flipped it doesn't appear the connections will mesh. Ralph
из
Pic 1 shows the bottom of the caddy if that what you referring to.
из
and thanks for your reply :)
из
Ok the drive layout will be fine, its just the connector I need to make sure of now, whether its still using the 6 pin sata power, all one connector (smaller than usual).
из
Добавить комментарий
1 ответ
Выбранное решение
Ok, got my answer. Should have looked in the spare parts section first.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) SATA SuperDrive Cable
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
iammacgyver будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,399
