Model M4753 / 233, 250, 266, 292, or 300 MHz G3 processor
21вопросов Показать все
Where did my hard drive go?
Yesterday I was using my PowerBook g3, and when i restarted, it could not find the heard drive. It could boot into a GUI phase, with a floppy disk and a flashing question mark. Any help?
Это хороший вопрос?
Оценка -1
2 Комментариев
What OS is it running and what is the latest install disk version you have?
из
Actually, I found the root of all evil, being that it cannot find the hard drive for booting. How do i do that?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Here's the procedure for replacing the drive: PowerBook G3 Wallstreet Hard Drive Replacement
The Wallstreet originally came with a : 2, 4, or 8 GB EIDE hard drive.
You can go up to a 128 GB drive with no problem. Just remember to get an EIDE drive.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Try booting with the restore DVD (or CD) that came with your computer and boot off of it. Then proceed to go to Disk Utility and see if your HDD is still there.If its there, its most likely corrupt, and you should do a Repair Disk command, but most likely its a goner so you want to buy a new HDD from ifixit or newegg.
Оценка 1
Добавьте свой ответ
Erik Sandberg будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 711
