Why is it malfunctioning after replacing the battery?
I have replaced the battery as directed. The display lit up, with a blank screen upon powering up...but that's all. After approximately 2 minutes it beeped twice, and there were dark bands on the lower area of the LCD display. Now it just beeps every 2 minutes.
After being plugged into a charging dock for 30+ minutes the lower half of the display has alternating bands of black and dark grey, and is still beeping twice every 2 minutes.
I used a soldering iron that was not calibrated...might I have fried the pcb?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
The problem you describe is due to damage to the screen.
The beep you describe maybe that replacement battery that is not good ..
If I were you I would try to change the screen display, do not think that damage to the PCB because it lights up.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
maryellenhart буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 438
