Comprehensive set of repair guides for playthings for children of all ages.
LeapFrog Read with Me, Violet battery compartment not working?
I just recently bought a LeapFrog Read with Me, Violet. The battery compartment was rusted. I couldn't get it replaced since I brought it to another country before checking it properly. How can I fix this?
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
If its just the battery terminals corroded, open it up and remove the terminals/battery compartment if you can. Lightly file or sand with a really fine grit sand paper, the corroded terminals and wipe the rest off, with vinegar. Also, check the soldered connections to the wires that are attached to the terminals, as they might have been damaged.
Oh, and be careful when doing this as the stuff you are cleaning off is an acid and can cause injury. Make sure you do not touch it with open wounds and do not touch your eyes etc and thoroughly wash your hands after.
This guide should help you as well; http://www.wikihow.com/Clean-Battery-Cor...
Hope it helps mate
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Mahir будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 618
