Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2396вопросов Показать все
Black screen, ribbon cables intact, battery OK, restored
my iPhone (used only as iPod, no cell service) has a black screen nearly all the time. Occasionally, on pressing Home or Power buttons, active screen appears. Shows as working when connected to my MacBook via iTunes. I recall 2 or 3 occasions before this when screen was black when I thought the phone was on; this may be the relatively sudden advance of an earlier-begun "disease." I have so far reset it (no help) and restored it--twice. Still (almost always) black screen. Between restores, I popped the back, removed battery, and unhooked and rehooked all the easily accessible cable connectors (they all seemed snug when I pulled them). So I had the battery out for that time. Most I've seen of the screen was when it came on during/after the first restore, and looked normal while it lasted. Doesn't flicker or distort, just goes black. Battery, last checked, seemed to hold decent charge, so I'm suspecting deeper trouble. No major drops that I'm aware of. Saw a YouTube vid about a black screen repair job where someone replaced battery, then some other part, neither helped, then the "digitizer." What's that and could that be the trouble? And worth the repair. I'm comfortable going in again to replace parts. Thank you!
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Sounds like a faulty display just because it has had no major drops doesn't mean the screen cant go bad.. Replace screen and see if that fixes it
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
So you mean this part?
Product code: IF182-003-1
Could it possibly be a bad battery that isn't reporting charge accurately? (Well, it's a cheaper fix anyway!)
Thanks!
из
Добавьте свой ответ
jamminactor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 127
