The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Can I upgrade from 4GB to 8GB RAM memory?
I have a MacBook Air 11" mid 2013 that came with 4GB RAM and 128GB hard drive. I want to upgrade the RAM to 8GB so I can run Vmware more efficiently with windows 8.1 and other software that don't run on the mac-side.
Это хороший вопрос?
Счет 5
Добавить комментарий
1 ответ
Выбранное решение
Sadly, no
Apple soldered the RAM to the logic board. You can upgrade the SSD! It's replaceable.
Был ли этот ответ полезен?
Счет 5
2 Комментариев:
Could you replace the entire logic board with one that had 8gb of RAM rather than the original 4gb?
из
Swapping out the logic board with one that has 8 GB of RAM is possible!
But, the cost factor for doing this then becomes the issue. I would recommend locating a used system which is newer as being a better investment.
из
Добавьте свой ответ
Rich буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 37
За всё время: 5,178
