The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Вопросов 20 Показать все
Why my phone reboot continuously?
I've try to format it, taking it to factory mode but nothing, it reboot continuously.
I've tried to replace battery, removing sd card....nothing!
What can I do?
Thank you.
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
They could be signs flash component is not good ... like galaxy 3 problem
Check with this software and see if the component is problematic
https://play.google.com/store/apps/detai...
If so, it's only a matter of time until the phone stops working and then have to replace the component.
This is called "sudden death"
If the check is ok try to wipe all and see if its ok
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Fixmart Laboratory, careful with referring to your own repair shop in Answers, this can be looked upon as Spam. Refer to your user profile.
из
Добавьте свой ответ
Gianluca будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 126
