Replaced iPhone screen turns off and on now?
I just recently replaced my iphone 5s screen and everything was good until I went to power on. I just got blue lines and the screen glowing up and it cycling on and off. I dont know what happened or whats going on but when I went to check my work the connector closest to the batttery was lose and doesnt want to lock in place also the vertical one directly above it. I dont know if I messed up the connectors or something else but my phone wont do anything. I saw a picture of a low battery logo pop up for a second and that was about it. Anyone have any issues like this and can point me in the right direction? Thank you guys
Это хороший вопрос?
Blue lines while your phone is turned off?
While phone is turned on , If you have a mix of pink , then blue , then yellow colors appearing on your screen that means your screen is having issue and need to be replaced
Otherwise I don't think you have a screen problem ....try to charge it and do the unfreeze procedure ....It might help
из Bassel
Other thing that might also help , try to remove the screen and connect it again properly without using a metal screwdriver ....the connectors might works fine
из Bassel
