The dual SIM version of Nokia's C2 series, released in 2011.
9вопросов Показать все
How do I re install software on my dead Nokia C2-00
I came across this software update notification on my C2 after which i choose download and install. All went fine until the end when it finally restarted and gave a message" contact Service in white and the screen was a ll black. I tried to switch off but it was all non responsive. Now nothing comes on so am here to know if this is salvageable or I just forget it.
Regards
Zed
Это хороший вопрос?
Оценка 20
Добавить комментарий
6 Ответов
Наиболее полезный ответ
have you tried to take battery out, and re-insert into phone. What happens if you do that?
Был ли этот ответ полезен?
Оценка 4
3 Комментариев:
..Apparently yes, I recharged the phone just to be sure but even then, nothing came on the screen to show charging was in progress so after that I have removed & reloaded the battery, tried to power it but nothing comes on...
из
Then i would contact warrenty, because if the issue is data corruption or damaged certificate - it can only be fixed in a service center using a flash jig.
из
Ganon pare pag ginwa mo tan
из
Hello, I am also facing the Same Issue :( is There any Solution please?
Оценка 1
I am also facing this problem in my Nokia C2-00, I removed the battery and again inserted in the phone but it is not working, my phone is just showing white screen.
Оценка 1
Same Issue i want nokia c200 os software
Оценка 1
hardware id pass word forgoten .kinly send me nokia C2.00 soft ware id pass word
Оценка 1
muje mobail pdet karna he
Оценка 0
Добавьте свой ответ
zbundi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 15
За всё время: 20,085
