Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
iPhone says "This accessory may not be supported"
When I connect my iPhone to the charging cable, it vibrates and says something like, "The accessory may not be certified." I've tried a lot of cables, including original Apple cables, but the results are the same. I've also tried to put my motherboard into another working case, but it does the same thing. Do you know which IC can be broken on my logic board? Thank you.
Это хороший вопрос?
Оценка 294
135 Комментариев
Have you tried an other charger and not cable?
из
Yes.. I've tried lot of chargers cable and usb from pc..
из
having the exact same problem too mate, bloody useless, so unreliable, so frustrating!! unbelievable, i love my iphone but im slowly having enough now, i am on my 3rd iphone, ridiculous, started looking for androids, so reliable in comparison with apple.
из
im having the same problem with my iphone 5s! what is the solution?
из
My iPhone 6 is doing that same thing now, any tips how to fix it? Every time I go to plug it in to charge it, it won't work. That one msg keeps poping up, do I just need to get a new charger?
из
Показать 130 больше комментариев
Добавить комментарий
26 Ответов
Выбранное решение
This is a common issue when it comes to the lightning charger. These are a lot of solutions that I got from here
Был ли этот ответ полезен?
Оценка 75
18 Комментариев:
Also a eyeglass screwdriver. Very narrow , cheap and fits in slot
из
Didn't know I could have so much lint in that little slot. I always carry my iphone in my pocket port up but I see it didn't make that much of a difference. Worked great! I know this may sound strange but tell all the folks who try this to turn your phone off first!
из
This happened to my iPhone 6 Plus and all I did was turn off my phone power, wait around a few minutes then turn on your phone. It should work as good as new!!
из
I meant that I turn off my phone when I go to charge it and it says that my phone doesn't support this accessory
из
Managed to actually come up with a solution to this after realising that when my phone completely ran out it would charge enough to turn on then come up with the message again..
Step 1: plug in your phone and dismiss the error message
Step 2: turn off your phone, leaving the charger plugged in
Step 3: leave for a couple of hours or as long as your phone usually takes to charge
Step 4: turn your phone back on. It will have charged as turning it off means you don't give it a chance to come up with the error message!
You'll have to do this each time you need to charge - it might be inconvenient but it's better than a dead phone! Hope this helps :)
из
Показать 13 больше комментариев
Hello, experienced the same problem for a month until I finally decided to take a push pin...Yes, a push pin and very carefully inserted it into my phones charging port and to my surprise..out came a lot of pocket lint from carrying it in my pocket!! Very easy process of just "picking" out the lint which was not allowing my charger to fully insert and make a proper connection. After doing this, my charger fit snuggly into the port and just like that...CHARGING AGAIN!! Try this simple, inexpensive fix and you all may be pleasantly surprised!!
Оценка 59
42 Комментариев:
This was the perfect fix for my iPhone. I forgot that I have to do this periodically to remove little magnetically attracted debris from my magport--add why wouldn't lint do the same on a lightning port. You are brilliant and I am in your debt!!!!
из
this is the solution i was looking for. I used a pin and cleaned the charging port and found lot of lint inside it and once cleaned it started working fine.
из
it worked! I used a pin and removed some tiny debris attached to the little magnets in the charging port... and now is charging !
thanks! :)
из
Worked like a charm! From now on I am making sure I put it in my pants pocket with charging port on top. Many thanks!
из
My daughter's iPhone 5c and my iPhone 5s came up a day apart saying this accessory is not supported. Yes we have different cables not chargers cause the original cables that came with the phones aren't very good at all. We are updated to the newest software. Why is the cable and charger a problem when the charger is right and not the cable? Apple should be happy we have their product. Instead of thinking of how to make a iPhone better, they should look into the cable and charger to make them more better. This is so crazy and us Apple users have to suffer cause we are using different cables and chargers and may not allow to charge our phones??????
из
Показать 37 больше комментариев
Here's what worked for me which I found via an iPhone forum. Plug your charger in, when you get the message "this accessory..." Hold your finger(with pressure) on the dismiss button and pull your charger out. While still applying pressure to the screen, plug your charger back in and it should work.
Оценка 28
57 Комментариев:
That worked! Awesome.
из
That did not work at all. I have a 6.
из
That worked for me too!!!!!! Thanks!!!! I wonder whats the real problem. Is it software or hardware.
из
Where is dismiss button@ or you mean home button?
из
This worked for me perfectly!
из
Показать 52 больше комментариев
Hello , this is how is this issue today and worked for me -
Source- 5 ways to fix accessory may not be supported error
1- clean the charging port of your phone carefully using brush Or toothpick
2- try branded cable instead of local cable
3- dismiss the error while charging and wait for sometime
at last you can also make sure your charger contact is not broken Or Mismatched
Use a pin to align the charging metals connectors
See if this seems to be helpful
Оценка 7
5 Комментариев:
thank You So Much ..it did helped me ...thanks a lot
из
I changed the charger and the cable worked even a very old iPhone cable, so it could be down to the charger unit not the cable in my circumstances.
из
Hi, my ipod apple keeps saying this accessory may not be supported and i click it and it stays
из
If you try to charge your iPhone and it states, "This accessory may not be supported," the problem could be with your iPhone's a software. I hаd a similar іѕѕuе when my iPhone was giving me errors.
I recommend you find the solution here :https://bit.ly/3iV7OmD
Hope thіѕ helps.
из
My iPhone still keeps doing the same thing after cleaning the charging port
из
arely, when you plug an iPhone or iPad into a particular Lightning charger cable you’ll see a pop-up or lock screen message on the device that says something to the effect of “This cable is not certified and may not work reliably”. This usually prevents the lightning cable from charging the device as well. Though most users will never see this error, if you do see that message, there’s almost always a reason why.
We’ll cover the three most common reasons you’ll see the “not certified” message on an iOS device, and also what you can do about it.
Perhaps before anything else, try pulling the cable out of the iPhone, iPad, or iPod touch, then putting it back in. Also, try plugging the cable into either a different USB port on a computer, or into a different all outlet. On rare occasions where the message is displayed erroneously and for no good cause, this can be a solution, which is probably indicative of a power issue with the source, and not the cable. These situations can also sometimes lead to an appearance of a device that refuses to turn on, though in such a situation just plugging it into a different outlet can be the remedy.
So assuming that is not the case, here are the most likely reasons why you’d see the “This cable is not certified and may not work reliably” error message with an iPhone or ipad.
The Cable is Junk or Poor Quality
The first and most obvious reason to see the error is when a cable is not certified by Apple, which is often the case with a cheap replacement. Sometimes they work and sometimes they don’t, when they don’t work is when you’ll see the “This cable or accessory is not certified and may not work reliably with this iPhone.” error message show up.
Because the iPhone and iPad Lightning USB charger cables can be expensive, many users will turn to the third party offerings to replace a torn or frayed cable, and these cheap low quality replacements are the most common causes of that error message. Those cheap cables are not recommended for exactly that reason.
Rather than risking it and throwing away money, just buy a cable that will work. If you don’t want to spring for the Apple cables, the AmazonBasics Apple Certified Lightning Cable from Amazon are cheaper, stronger, and work really well.
While I like the Amazon brand, any certified cable should work, and a legitimate Apple Certified cable will usually have a “Made for iPhone / iPod / iPad” branding logo on it, kind of like a stamp of approval from Apple (you can read more about that here).
The Cable is Damaged
You may also see the “This cable or accessory is not certified and may not work reliably with this iPhone” error message with a damaged cable. This is particularly common if the charging cable has been submerged in water, corroded, or obviously damaged in any way, with fraying or chew marks that are clearly visible. If that’s the case, you’ll want to replace the cable anyway.
Again, the Amazon brand cables are good replacements and reasonably priced.
Less Likely, Something is Obstructing the Cable Charger or Port
A much less likely reason to see the error message, but still a possibility, is that something is physically obstructing the port or the charger. Basically if something is stuck or obstructed just enough to send a signal but not work properly, you may get the error message.
Most commonly however, is that something like pocket lint or pocket crud gets jammed in the port and will prevent charging from happening entirely, and in those situations you usually don’t get an error message at all because the port is so jammed that no current or signal is passed. This is more likely to happen with an iPhone, but I’ve seen it on an iPad where carpet lint and even Playdough was jammed in the charger port, and causing a periodic “not certified” message to show up. So check the ports and clean it out if you see anything in there, in some situations it can be a simple solution.
Оценка 5
6 Комментариев:
Are you apple guy? Your answers are familiar with the Apple service in my country. Well, I have 5 iphones and 4 ipads in my house and did whatever you said as well Apple service personal in my country. None of those work for me.
из
These are all the standard Apple canned responses. Truth is it's the iOS software looking for non-Apple branded charging gear so they can force you to buy Apple hardware to charge your Apple phone, or better yet, talk you into "upgrading" to the latest device; even though you might have JUST gotten your device set up so it's comfortable and easy to use.
Now Apple has started putting an IC in the charging cable that tells the phone what it is; and every time the iOS updates, it reflashes that chip so it's always changing.
And NO... this is NOT about Apple maintaining "Quality Control" over their devices; it' all about them locking users into their "Aspirational Brand Ecology" whether they want it or not.
I have both Apple and Android products in my home; and the Android devices don't have ANY of this BS EVER.
I can charge ANY of them with ANY brand or generic micro-USB cable from AYTHING... using ANY power brick from ANYTHING. Unless the brick or cable is actually DAMAGED, it works. PERIOD.
mnem
*Juicy*
из
The worst thing that happens is occasionally, like if I use a cheap-cheap $1-store micro-USB cable that's obviously thinner than Cappellini pasta, it will pop up a message saying "this device may charge slowly" or "For Faster Charging Use Original Charger".
BUT THEY STILL CHARGE. In most cases, they will still charge fully overnight.
This is part of what you bought into when you bought an Apple product; their expensive but very attentive customer-service oriented ecology.
If you want to do things with your Apple product for yourself, you've bought into the wrong brand; you want an Android product. ;)
Of course with Android, half the time you HAVE to do it for yourself... this is a double-edged sword. :p
Cheers,
mnem
*iPwned since nineteen-mumblety-mumble*
из
It is indeed a matter of buying good cables and a good charger block.
I use Belkin chargers for all of our iPhones (Yes; Apple certified) and never have a problem.
The chip in the cable is not there to maintain a "vendor lock", but because the cable is also an intelligent high speed data cable. It can do much more than just charge your phone . .. in contrast to many charging cables used for Android devices.
And no, the chip is NOT reflashed every time when there is a phone update. That would also be highly impractical, as in that case the cables could stop working for certain devices. From my experience I can tell that is NOT the case.
из
Certainly not an answer, but I have to say it is sad that the most obvious answer is never mentioned anywhere (certainly not on Apple forums). That obvious answer is that it is a bug in the operating system. If Apple were a more customer centric company, after reciving the same inquiry 1000 times they would have gone beyond the "canned" answers and instructed their programmers to trace the problem and either make a fix, or offer customers a work around. Lets face it, coming up with an "unsupported device" error is a reasonable error. Purposely cutting off the available charge voltage from reaching the battery charging circuit is a major blunder on Apple's part.
So far the only work-around I've found that always works is to dismiss the error, disconnect the charger, plug it back in, and wait at least a minute to make sure the error doesn't come up again.
из
Показать 1 больше комментариев
The usual problem with this is that the cable you're using isn't a genuine apple cable but as you've said you have tried the original then the only other explanation is that it is the charging block itself that is the problem. After a while with iPhone 5's lightening charging block is that the gold plates inside start to score and once they are marked they are damaged so they will not function as how it used to do. Only suggestion is that you consider replacing the charging port that you can purchase from here and follow some simple steps also provided by iFixit. Hope this helped.
Part: iPhone 5 Lightning Connector and Headphone Jack
Tutorial: Замена коннектора Lightning и разъёма наушников iPhone 5
iPhone 5 Lightning Connector and Headphone Jack Изображение
Продукт
$19.99
Оценка 4
4 Комментариев:
Hi, thanks for answer, in my iphone 5 i've already tried to change the dock connector and also tried to put my logic board in another working iphone.. So the problem is in the logic board for sure
из
yes the golden plates on the inside must have been damaged mate, so fragile, best advice is take it to your nearest phone repair show and ask the damage, sorry buddy! good luck!!
из
(Iphone 5)I've tried the lot. I put my phone on aeroplane mode and put the charger in, then the phone went off, then i got my other iPhone charger and put it in and its charging...i think. But the phone is still off as i don't want to turn it on to see the horror message. Its got the charging sign. Thanks for different ideas tho. :)
из
Had same problem - O2 sent me a new phone.
из
I had this problem and tried every fix including; reset, cleaning, different chargers, soft re boot, airplane mode etc. It was driving me mad!
Apple telephone support couldn't help and it took loads of attempts to get it to charge until I found my own solution:
Plug in your charger to the phone and power supply
'Ok' the annoying message - 'accessory may not be supported'
Turn the iPhone off while leaving the charger plugged in and switched on
When you turn your phone back on having left it for a while the charge will have increased. Turn it back off and leave it for a while longer and it will be fully charged
This has now worked consistently several times - happy days!!
Not perfect as you have to switch your phone off but, it works!
Оценка 4
3 Комментариев:
why would you turn it on to turn it off again?
из
Thanks it worked a little
из
This is 100% U2/Tristar/1608A1 IC Failure. For a permanent solution, you can find someone to replace the IC. There's actually very little of them around capable of this, but you should be able to find someone at http://boardrepair.info
из
Try replacing the charging port. This was probably mentioned somewere in the 99 other post Just wanted to make it an even 100 answers
Оценка 3
1 Комментарий:
I've tried all the solutions mentioned above such as cleaning the port, turning off and on, the tip with the "dismiss" thing, the airplane mode... Any of them worked out, and I've tried another cable, it now charges... I think my Apple cable is damaged... I've tried with non Apple cable (Energizer) and it works... :)
из
I had this problem, and it was my a lack of power from the power outlet. I try a different one with my iPad A/C and it worked without a problem.
Give it a shot.
Оценка 2
2 Комментариев:
hey my tablet only charges when i dont move it and if i move it it will take all the power away and shut down i need help for that problem
из
Tried this no luck. Apple is so frustrating.
из
If you get an error message on the charger, this usually means that the iPhone does not see the supply voltage and charging current it needs.
So there is something wrong in the chain from;
wall charger - lightning cable - iPhone connector
Procedure to follow:
1) First check metal contacts on all . Should be shiny gold.
If not shiny: clean with soft plastic pin or wooden tooth pick (no metal pins!)
2) Non-Apple cables may have too thin metal wires, which restricts the current flow.
Solution: Buy an Apple certified one.
3) Non-Apple chargers may have too low supply voltage, which restricts charging power.
4) Non-Apple chargers may have too low supply current, which restricts charging power.
5) Cable may have broken metal wires inside (e.g. due to rough treatment)
Solution: Buy a new Apple certified one.
- This should solve the charging problem.
Оценка 2
6 Комментариев:
Sure hope your commission check from Apple get to you!
из
So what's your solution if you're getting this error message while using the original charging port and cord that came with you iPhone. Is that not Apple certified?
из
Then you should apply for the warranty at Apple. In case it has been roughly treated or just very long used (several years), it may have broken wires inside the cable that restrict current flow. This usually happens a lot sooner (than after several years) with other brands.
из
Alas, no commission check from Apple, as "Apple certified" in general means that some producer (e.g. Belkin) is selling a charger that is certified by Apple. It could also be Apple, but not necessarily.
из
F**ken Apple
I'd like to call them soul sucking parasites who build Dodgy tech and charge top dollar for it but that would be too complimentary.
Seriously - their answer to everything is, "go buy apple brand"
I'm using a Gen 1 iPad with my original charging chord and wall plug. It started doing this crazy unsupported bullsh1t recently and I wholly believe they have built their devices to have minimal lifespans.
I am the only person I know who never did Apple's bullsh1t IOS updates and I am also the only person I know who's Gen1 iPad works.
They realised people had cottoned on to their IOS update scam and found other ways to be d1cks.
News flash Apple. Get this through your thick heads - when we pay your extortionate costs to buy an i-device - it becomes ours. Solely ours and ceases to be yours.
So stop trying to inflict your will on us with our property!!!
I swear to "God" (if you believe in that make believe fairy tale) - I may just deck the next Apple Store Employee I see - out of principle.
из
Found this on another forum. Try putting the phone into airplane mode first and then charging. It worked for me.
Оценка 1
5 Комментариев:
it worked for me!!!
из
Worked for me too! But why? Now everytime I want to charge my iPhone I'll have to put it into airplane mode?
из
из
Still got the message.
5s
из
Means that the charger or cable is faulty, but still is okay when the phone draws low current.
This is the case in Airplane mode, but even better would be to shut down the phone completely during charging..
Best solution is still to replace the cable and charger by a new "Apple certified" one. (So not necessarily made by Apple, but some brand and model approved by Apple; e.g. from Belkin.)
из
Unplug the USB charger from wall plug and charger cable. Unplug the charger cable from your phone too. Plug everything back and that should do the trick. It just worked for me.
Оценка 1
1 Комментарий:
This is so simple but this is what worked for me! I have an iPhone 5s
из
I just cleaned the charger tip and all was fine
Оценка 1
2 Комментариев:
Just the tip? ;)
из
I did the same too and it works. cleaned the charger tip :)))
из
This sounds the effects of a cheap lightning cable. Using a USB cable that is made of the highest quality materials will prevent the error message from appearing and guarantee that you'll always have a good cable handy.
Оценка 1
I have changed my charging port twice. Tried a lot of different cables.
I finally discovered,If I leave my phone laying for about 20 minuets, plug in the charger and it charges. Either that or charge it with the phone turned off.
Its a pain in the ___ but my Iphone 6 is 9 months old (Refurbished).
Update (09/21/2016)
I replaced my logic board with one from a different phone just to prove its the u2 chip. Then but the original one back now everything works great. Did something need to be reset? Was there a bad connection somewhere? I'm not sure why. But I'm just glad to have my phone back.
Оценка 1
I can say with near 100% certainty at this point that the problem is directly related to how well the power source maintains a solid 5.0 volts when connected to your phone. A few 1/10ths of a volt more is tolerable, but less is definitely not. So why is this "voltage" problem happening? Well unless you're a fairly "techie" person, you can almost skip this next paragraph because its a case where knowing "why" is about as helpful as a sick patient asking "why" he/she has the disease causing their pain. Unless you're a doctor with some "fixes", knowing "why" doesn't help fix anything. But for some i t might.
The "why" of it comes down one of two causes. First, the voltage coming out of various USB based 5V sources ( even from some decent chargers) may be slightly "off", and second, even when the voltage is perfectly correct, it may be a lot lower at the other end of the charging cable! To test it both of these conditions, you literally have to sacrifice a cable by stripping some of the cable covering near the phone side, then striping small segments of insulation from a few of the inside wires (there are usually 4 in any USB cable), ultimately isolating the wires containing the 5V and 0V common. If they are color coded RED should be positive (+) and BLACK Negative (-), but sadly all of them aren't color coded. Now once this is done, you'd have to carefully measure that voltage with a multi meter, preferably a digital one (DVM). Without the phone connected, you should measure anywhere from 5.0 to perhaps 5.3V tops. One I have here that often gives me the problem was found to output 5.25V. Great! In fact if a charger didn't put out good voltage with no phone plugged in, then its total garbage and is always going to be a problem! So assuming you have decent voltage at "no load" (no phone)", the next thing to do is plug in the phone while watching that voltage. Oh now its not so good right? The one I had dipped down to about 4.3 volts momentarily and recovered to about 4.45. (If you look on faster measuring device like an oscilloscope, you'll likely see the voltage dip even worse!) Why? Two reasons. First, the voltage regulation in the supply is not so good (poor circuitry) and Second, some voltage is always lost because of the relatively high current being drawn over VERY thin wires. So both the charger AND the cable that came with it are each partially at fault. Trust me... if you were to use a technicians bench power supply and adjusted it so that at the point you are measuring (near the phone side of the wire) is actually 5Volts, not only will you NEVER see "device not supported", but your phone will charge a lot quicker!
So is 4.5V enough? Well consider that the Lithium cell in your phone, at full charge, should reach 4.2 volts. Realizing this, you can see where 4.5V is barely adequate, and something around 4.3, even for a short instant, is probably going to trigger an alert inside the 'smarts" of the "smart" phone. At best it will charge slower than it should, and at worst it will make the dumb phone think "hey this isn't a charger... it can't be... the voltage is WRONG too low! So I guess it must be some other device, and since I can't talk to it, its not a supported device!). It then internally disables the charging circuit, because wanting to protect it self from the opposite of charging... DISCHARGING. Could apple fix this? I'm sure they are aware. But they are treading a fine line!
Now its already been mentioned that a dirty or poor contact can cause the problem. If you think of an old fashioned flashlight (not so much the LED kind), you probably have seen where as the battery gets weaker, the light output of the flashlight can sometimes be restored a little by banging the flashlight in your hand (the great American 'fix-all" :-) ). Well this is the same reason why it is often helpful to keep the contacts clean. But electrically, the best thing to do is often difficult. If you're dealing with a newer I-phone which has a standard USB plug on both ends, you may be able to keep your inexpensive charger and obtain a better cable. Look for the words "high current" or current ratings of "2 amps". If its an older I-phone with the "apple only" connector, finding a better cable will be a challenge. Especially with the way search engines "ignore" search terms it can't specifically find. The problem is that a higher current cable means thicker wires, and everybody wants a thin "spaghetti" like wire. If you can find one with a thicker wire, there's a good chance you'll have a fix. And definitely look for the shortest wore possible, since the voltage drop decreases with shorter wire length.
If you're really technically capable, you should be able to find some much thicker USB cables meant for something other than an I-phone. If you keep the USB side and cut off the other side, it is definitely possible cut off the phone side allowing a couple inches of wire, and splicing the two together. Of course you'd have to solder, re-insulate, and cover the whole splice with heat shrink tubing, and this method is obviously not for anyone who doesn't know which end of a soldering iron to hold. But doing this will likely bring up the voltage to the phone by as much as a volt, and will definitely solve your problem. Again, if you're a DIY electrical person, you can build a variable DC power supply good to about 1.5 amps or better, with a USB port, and then following the measurement procedures mentioned earlier, set it to whatever voltage is necessary (with the same cable) to get the voltage at the phone end up to 5.0V. You're final charger will probably not be as small or convenient as the "itsy bitsy" ones you can buy dirt cheap, but it will work well and charge your phone a heck of a lot faster!
Unless such a project is within your grasp, you're going to have to pay a little more for a charger that has good reviews and has been shown to be actually rated for high current and fast charging, has specs to prove it, and has specs by a believable source (You know how much outright BS is published by "no-name" companies from 'certain" countries). This and following all reasonable procedures o keep the contacts clean in your i-phone port will help. Sometimes just plugging them together and apart several times will help. Good luck everyone!
Оценка 1
Also tip* if you an older phone, don't update to new IOS, because it created a problem for me.
Оценка 1
1. plug your charger into the wall
2. turn of your phone
3. as its turning off before u see the spinning circle plug it in
4. wait for it to charge
5. turn the phone on and unplug charger
Оценка 0
Hi
1, Plug phone into charger
2. Dismiss notification about accessory not supported
3. Turn on airplane mode
4. Turn off phone for 2 mins (leave plugged in)
5. Turn phone on and turn airplane mode off
This fixes it! :)
Оценка 0
1 Комментарий:
No it doesn't. I have to do this almost every day. I still get the same comment. And I am using the original charging cord that came with the phone.
из
I had this problem since updating, and it didn't dawn on me that since I had it plugged into my laptop, it was my antivirus that was disconnecting the feed.
Plugging into the charger worked fine. I had to turn off my Kaspersky so I could sync the phone. (I'll fix my Kaspersky when I get time to stop this from happening).
Оценка 0
I followed these threads and tried a lot of what was recommended to no avail, and finally took the issue to the Genius Bar at Apple this week, before I lost complete power on my iPhone and iPad. Turns out the issue was with the cable itself, and because the cord did not show wear and tear, Apple replaced it for free. End of story, and it's been working every since with no issues.
Оценка 0
well it's most likely the cable !
Оценка 0
Posted this almost a year ago but I haven’t realised til now it wasn’t it’s own comment so in the interest of helping more people, here’s what has worked consistently for me since then - I still have the same iPhone and still use the same method to charge it, even though apple told me the ONLY solution was to get a new one!! Enjoy :)
Оценка 0
I hope this helps someone. What I did to get mine to charge after having this issue was turn off the wifi, put the phone on airplane mode, and then turn off my phone. After restarting give it a couple minutes, and then plug your charger in.
Оценка 0
If you have an iOS update pending you’ll get this message. I’m sure it would take Apple minutes to crate a popup that states “you need to update your phone before you can transfer files” but for some reason they haven’t bothered. We went nuts for an hour trying to get an urgent transfer off the phone onto multiple devices only to get this message. Everything worked fine once we just updated the phone.
Оценка 0
You may get an “accessory not supported” alert if you're using counterfeit accessories. To prevent this, make sure that the charging cable and accessories you're using to charge your iPhone are MFi-certified, meaning they were made according to Apple's design standards. MFi means Made for iPhone, iPad, or iPad
Regards,
Will
Оценка 0
Добавьте свой ответ
edoardo rossi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 107
За последние 30 дней: 414
За всё время: 1,944,364
