The driversdoor doesn`t work
where can I find the driversseatmodule to change it ?
is in the door or near the engine ?
thanks . peter
Это хороший вопрос?
thanks . peter
Это хороший вопрос?
sorry . i forgot it . it is a XK8 from 2001 .
thanks . best regards . peter
Был ли этот ответ полезен?
Its under the seat, attached to the seat itself. By far the easiest way to get to it is to just take the seat out (undo the 4 big Torx bolts, one at each end of the 2 seat rails, then undo a connector to disconnect the seat wiring). You need to move the seat forward and back to get to all the bolts so leave the connector till last. Other than that its a no brainer and takes about a minute.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 321
what model is your JAG?
из oldturkey03
