iMac 21.5" EMC 2544 LED Backlight problem
I opened my iMac Intel 21.5" 2.7GHz to replace my HDD. Now when I've turned it on, I can see the display with a torch. LED Backlight is not working , however after 20-30 mins, it comes on to full brightness and remains on. If I put it to sleep or turn the display off, it doesn't come back on. I have set the display to never go to sleep, this way I can at least work. However, the screen brightness does not change at all, no matter if its at minimum or maximum.
I have done the AHT and it says there is no problem.
Also, there are 10 glows from the bottom suggesting that there are 10 lights lighting up the screen from the bottom. Between those glows, there is slight darkness, and on the bottom edges too.
It looks like this.
https://www.flickr.com/photos/29671511@N...
Also, I'm not sure what or where the problem originates, but my guess is it is the LED driver board. There is a tutorial for the thick iMacs (link given below) but not for the slim ones.
iMac Intel 21.5" EMC 2308 LED Driver Board Replacement
I am in Pakistan and there is no official Apple store, just certified vendors but I cannot go there without being absolutely certain that I'll be ripped off.
Это хороший вопрос?
