Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
No picture on LCD but backlight works
I'm currently working on an iPad Mini Retina wifi and can't figure out why there's no picture on the LCD but the backlight works. It's clear as day that it's lit but nothing shows up. The device syncs to iTunes but I think it needs to be unlocked or something since it won't let me in.
I've tried multiple LCD's and the exact same thing. Not sure what else could be wrong. I'm assuming it could be a fuse or resistor on the motherboard but I don't know which one or where to search for it. I'm assuming it's next to the flex connectors on the motherboard. If so how in the world do I test those? They're like the size of lint!
Please help!
Это хороший вопрос?
Счет 5
5 Комментариев
No clue anyone?
из
из
Did you ever find a solution to this? I am experiencing the same problem now.
из
I have this same problem. If I plug back in the old LCD it has a picture. But the new LCD only the backlight comes on, no picture.
из
has anyone had a solution for this?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Tap around the back of the frame. Sometimes this causes it to come back on, for whatever reason
Был ли этот ответ полезен?
Счет 1
maybe you did not connect the ribbon cable in all the way sometimes that the culprit . sometimes we get in a hurry putting thing back together. or could bent it jus a little.
Счет 0
Добавьте свой ответ
npham54 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 1,534
