The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459вопросов Показать все
Can I replace my S3 LTE korean E210s display with non LTE S3 Display
hi can you please help me
i cracked my EmoLED screen but the touch screen its not broken on my galaxy S3 LTE - Korean LTE with a model number [SHV-E201s]
i want to change the display
but the question is is there any difference between the Emoled screen ? specially the screen ports ( connectors ) on the main panel (motherboard )
or
can i use the galaxy s3 (i9300) EmoLED Display to replace my broken screen for my device S3 LTE Korean [SHV-E210s] screen with it
Это хороший вопрос?
Оценка 3
2 Комментариев
I had the same problem, i have shv-e210s touch glass and lcd screen damage and I'm unable to find same replacement kit with antenna support. Please reply
из
Some one please reply!!
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If you do not order the part on a frame, the display assembly will be a universal fit across the S3 models. I9300 can fit i747 can fit L710 and so on.
Был ли этот ответ полезен?
Оценка 2
Hi iwnt display and touch pad glass how much
Оценка 0
Добавьте свой ответ
khaled будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 4,060
