The LG VX5200 is a CDMA flip phone with an external antenna, 32 MB of onboard memory, and a 1000 mAh Li-ion battery.
4вопросов Показать все
Will I erase my text messages if I repair the logic board
The piece that connects to the charger is broken and I desperately want to recharge my phone to access my old text messages. If I replace this piece on the logic board will this erase my phone's memory?
Это хороший вопрос?
Оценка 0
1 Комментарий
Im having a simular issue but with a note 4 antenna port. So I replaced the charge port, the glass back (which cracked when being opened), and the charging port but in the process of putting everything back together again for the 3 time. I broke the antenna cable port when snapping off of the motherboard logic board. The antenna cables are fine but the port that the cables snap on to are broken. Does anyone know how to fix it or if I replace the whole part, will I still have my text messages and stuff?
из
Добавить комментарий
1 ответ
Выбранное решение
Trevor, no it will not.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Thanks. Is there a way to just transfer my phone's memory to another VX5200 that works? Or would it be smarter to replace this one piece? Or should I just replace the whole logic board?
Thanks
-Trevor
из
Trevor, ""Is there a way to just transfer my phone's memory " only if you know how to reball a BGA IC. I suggest you get a charged working, start your phone and transfer your files to another device (computer) than you can either resolder a charging port or replace the board. This will depend on your skills and $$$
из
Thank you. I have no soldering skills, and dont know how to reball a BGA IC. What do you recommend? I just want to read my old texts, see pictures, and listen to voicemail messages. -Trevor
из
из
Добавьте свой ответ
Trevor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 423
