Repair guides and troubleshooting for MacBook Pro 15 inch laptop computers with a non-unibody design.
1323вопросов Показать все
What is missing in here?
So i have a macbook pro i really dont know much but my hard drive is missing (on the bottom left corner next to the battery right?) and something i dont know the name for is missing also (above the battery) which is green (lol) EDIT Here is a pic without the battery in it. http://tinypic.com/r/311o22p/8
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
In the upper right corner of the photo (which is what I think you mean by bottom left here) is the space for the hard drive. The cable to connect to the hard drive is still there; any 2.5" SATA hard drive should work. The space is fairly thin, so you should use a drive that's 9.5mm or thinner; but most laptop SATA drives made these days should fit the space.
What's missing from the socket in the middle of the photo is DDR2 RAM (PC2-5300) - one or two sticks. How much RAM your machine can use depends on the generation of the machine; it ranges from 2GB (2x1GB sticks) to 6GB (2+4GB sticks).
The generation/model number is marked on the back. A1150 has a Core Duo CPU; A1211, A1226 and A1260 have Core2 Duo CPUs. We'll be able to give you a lot more guidance once we know what machine we're dealing with.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I would add you should see if the system is even working by first installing a memory module and seeing if the system powers up (power adapter & battery). Even without a hard drive you should see a blinking question mark. I suspect the system was stripped because it is not working anymore.
из
Добавьте свой ответ
Eduardo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 46
