The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
cold water wil not come out
the water will not come out ,the green light stays on all the time
Это хороший вопрос?
Счет 4
2 Комментариев:
Mine isn't working, either!
из
I am getting hot water out of all taps even the cold one.
из
Добавить комментарий
1 ответ
I have an Oasis water cooler and just encountered the same issue. It turned out that the water in the tank had frozen. I searched all over for a manual and the only one I found was useless. I called the dealer and they said, "Unplug the unit, wait for it to thaw, then plug it back in." (Great solution, unless it just happens again and again!) So I asked, "what if it keeps happening?" They told me to turn the thermostat down (clockwise), so I thanked them and went to do that.
Surprise, I couldn't find a thermostat on mine. Yours may have one, though!
I suggest unplugging the unit for a while (giving frozen water time to thaw), then look for an adjustable thermostat. If you can find it, turn it counterclockwise a little bit. Then plug the unit back in and see if that takes care of the problem.
P.S. I realize you may not have waited 2 years for an answer, but, like me, someone may come along with a similar problem later. Hope this helps!
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Mine is frozen too. This is the first time it's ever happened and I've had if for 9 years! I am unable to find an adjustable thermostat. So I'm going to thaw it out, plug it back in, and hope for the best.
из
Добавьте свой ответ
Lloyd Harter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 7,263
