The Lenovo IdeaTab A2109 is a 9-inch multi-touch screen tablet released on August 27, 2012.
My tablet wont boot or charge
When i plug the tablet into the charger there is no response and when i try powering up i get a quick flash and vibration alhough it doesnt boot up, i have tried holding the volume+ and pressing the power button for different lengths of time and still nothing, the product is a little over a year old, it is a 'lenovo tablet pc ideatab A2109A-F' model:2290, any help would be great thanks.
Это хороший вопрос?
Счет 8
Добавить комментарий
9 Ответов
Наиболее полезный ответ
i have same problem
Был ли этот ответ полезен?
Счет 1
I have the same problem
Счет 1
my tab is continuously booting. how to stop that
. lenovo idea A2109A model
Счет 0
1 Комментарий:
Had same with A3300-hv just press volume up and down and power off button together it will work for booting
из
MY Lenovo IDEATAB A2109A is booting continuously when i swictedon and iam unable to any program with that pls help me to resolve this problem
Счет 0
The problem could be you battery or io port if you don't feel vibration. Its possible that the screen might not work too.
Счет 0
I have this same problem and everything I try to do it just doesn't work
Счет 0
my screen wont turn on or take charge any more
Счет 0
Has anyone thought to check the USB charge port by wiggling(GENTLY) . to see if a solder contact has failed???????
Счет 0
Hello! First try charging for 5 hours after doing it while plugged press volume up and down and power on/off button together you will get a vibrate ! . its a good sign. Try again for 30 seconds . Hopefully this will work!
Счет 0
Добавьте свой ответ
che gee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 35
За всё время: 3,367
