My MacBook Air Display is not working, it's broken? (I have a a photo)
I could put the photo now n.n, of my MacBook Air, I dropped it accidentally :( , but I want to know if my Display is broken or a cable inside it, what you recommend me to do?
Это хороший вопрос?
4 Комментариев
Can't access the image get: Unauthorized
из Dan
Kevin, use this guide to add images Adding images to an existing question
из oldturkey03
There's the photo my friends:D
из Kevin
Thanks for posting the image. Sadly I think old turkey is correct here your display has had it. You can also try connecting your system to an external monitor to help prove this. If the image is good on the external then its a sure thing. See if you can locate a full lid assembly while being a bit more in cost it will be a lot easier to replace.
из Dan
