Android-based handheld game console with both touchscreen and gamepad input capabilities, released by Nvidia in July of 2013. Initially dubbed simply "Nvidia Shield," now known as Shield Portable to differentiate it from other Shield products.
17вопросов Показать все
How can I replace my Nvidia shields flexo cable?
For a while now my Nvidia shield's screen has been randomly going all fuzzy and covered in static and i have been very careful with my Nvidia shield so I was very worried as you can imagine so I talked to someone at Nvidia and they told me its an issue with the flexo cable. anyone know how to replace a flexo cable?
Это хороший вопрос?
Оценка 5
1 Комментарий
How can a get a New Flex?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Abdullah Sajid, see if this teardown around step 11 is what you need.
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
thx man do you think i could replace my cable with this one? http://www.ebay.com/itm/OEM-NVIDIA-SHIEL...
из
that looks about right. Just take alook at yours and contact the vendor. this way you know it will be the right one for sure.
из
thank you i really appreciate it
из
did it work for u because i need help i'm in a similar condition
из
That flex cable that you posted is for the main board to the control board (i.e buttons, d-pad ect). I don't see how replacing that ribbon will solve your display issue.
из
Показать 1 больше комментариев
Добавьте свой ответ
Abdullah Sajid будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 2,178
