The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
39вопросов Показать все
Вопрос закрыт
My s 4 having signal issue. Please help
I bought a used s 4 and I just noticed it has signal issue. It shows the signals but when I try to make a call it drops all of the signals and call gets disconnected. I can't even receive a call. Please advice.
Thank you so much
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
To open the phone and make sure if it have the signal cable or if the signal cable is broken.
Был ли этот ответ полезен?
Оценка 0
Change your SIM card.
Оценка 0
Open your phone and unscrew(12 screws total)/GENTLY pry off your midframe. On the right side of your battery housing there is a Long blue Wire with a connector on each end. (This is your antenna) Carefully make sure they are securely fitted on the motherboard and daughter board. (Top and bottom computer boards)
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 179
